Windows not cutting walls
2 ANTWORTEN 2
Nachricht 1 von 3
lucasc
729 Aufrufe, 2 Antworten
I am working on an existing building that requires demolition and replacement of existing windows. I was able to place all of my existing windows in an existing phase and I was able to demo them properly in a demo phase. However, when I go into my new phase to place the new windows they will place in the wall properly and show up correctly in plan in section but in elevation they show as if embedded in the wall and in 3d views they show red as if they are being demolished. The view is set to the new phase and the window are created on the new phase. The phase filters are not overridden and no other element types placed in the new phase show up as red and ghosted. Does anyone have any potential answers to this issue? Thanks.
I attached a few photos of the elevations and 3d's to show the issue. Capture2.JPGCapture1.JPGCapture.JPG
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: lucasc
Phase Filter=Show Complete
Nachricht 3 von 3
Phase filter = Show Previous + New.
If no dice, you can try to select the window and use Pick Primary Host from the ribbon then pick the infill wall again.
