Hello.
The problem is where two identical windows are being cut by section, however the left one is not being cut correctly, as the right one is.
I have tried cutting other windows, but the problem persists only on this particular left side window. Any suggestions?
See png below!
Are their elevations correct? I'm wondering if the lintel extrusion isn't flexing properly.
I'm just wondering if the lintel isn't spanning the whole width of the window, making it so the section doesn't cut through it on the left instance.
