Hello everyone, can anyone help me? I created a new window, and part of it does not show correct in plan views, it does not cut. And in the visibility options is marked to cut Anyone know why?
Gelöst! Gehe zur Lösung
Gelöst von josemukalel. Gehe zur Lösung
Looks there is not enough constrains ,Please upload the files to have a look
Change the " cut level" from 100 to 120 in the window family ,then it will work
Yes, done it as well, this is the solution.
As well, while you are at it, you need to assign subcategories in the property panel to your objects (glazing to your clazing, etc...)
Or it won't display properly.
François
Francois-Gabriel Perraudin
BIM management and coaching
In the window family
see image
