Windows Dimensioning
5 ANTWORTEN 5
Nachricht 1 von 6
jfjacques
445 Aufrufe, 5 Antworten
If I change the size of the window using it's properties, it scales from the center.
Is there a way to scale it from either side, if, for instance, I want to keep it aligned with an object.
If I align a window with another object, usually the will shrink or stretch to accommodate. Other times it will not change size, but shift in place. Why is this? How can I control this?
The same applies to adjusting dimensions that define the windows place relative to other objects.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: jfjacques
Change the Location of the Origin Ref. Plane to the Right or Left Side, Pin it, and Remove the Equality Dimensions.
Nachricht 3 von 6
I think I misread your question, @jfjacques . Are you asking why windows "grow" from the middle outwards sometimes and other times from the left or right?  I would suspect you have a constraint on the right or left side, such as a dimension, which is preventing it from "growing" in both directions.  Reveal Constraints to find out what it is.
Nachricht 4 von 6
jfjacques
als Antwort auf: barthbradley
No this is it.  How do I access the origin ref plane?
Nachricht 5 von 6
Actually, you don't even need to change the Origin. Just PIN the "Right" or "Left" Ref. Plane in the Family to make it "grow" in one direction.
BTW: "Defines Origin" is a Ref. Plane Property.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
Nachricht 6 von 6
jfjacques
yeah will have to look up how to do that
