Please help, it is not possible to install a window on the floor plan, when I do it on the 3D view, it is not displayed correctly, what can be done?
Here's a list of 33 things to check when you can't see something in the View...
https://www.revitforum.org/forum/revit-all-flavors/tutorials-tips-tricks/459-
My guess would be the window is not within the View Range or View Phase .
Ah! I see what's going on now. You won't find the solution in that 33 list. You created Parts from the Wall. Edit Window Family and add a Masking Region to the Plan View. Or make all your Model Geometry Visible in Plan/RCP. No need for Symbolic Linework in Plan View then.
...or option 3: change the View's Parts Visibility to Show Original
