Windows Application error with Revit 2019
1 ANTWORT 1
Nachricht 1 von 2
601 Aufrufe, 1 Antwort
Working under Revit 2019 for a few months, I have been experiencing application crashes since the beginning. When I look at the Windows application logs here are the error messages I get:
Name of the failed application AdPreviewGenerator.exe, version: 2017.11.6.0, timestamp: 0x5afb97dc
Name of the failed module: AdMaterialUI.dll, version: 2017.11.6.0, time stamping: 0x5afb97c0
Exception code: 0xc000000005
Error offset: 0x000000000000000000236f16
Process ID of the failed process: 0x2dd0
Start time of the failed application: 0x01d47b365473c65f
Path of the failed application: C:\Program Files\Autodesk\Revit 2019\AdPreviewGenerator.exe
Path of the failed module: C:\Program Files\Autodesk\Revit 2019\AdMaterialUI.dll
Report ID: ff1b08dd-3179-4882-9988-4781835f91c9
Full name of the failed package:
Application ID of the application related to the failed package:
My configuration is as follows:
Microsoft Windows 10 64bits
Intel Core i7-7700K
32Go DDR4
Nvidia GeForce GTX 1060 6GB
Can you help me? Thanks for your support.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
