windows and doors not showing up
2 ANTWORTEN 2
Nachricht 1 von 3
834 Aufrufe, 2 Antworten
I checked my cut plane and it's fine but my windows and door dont show up. when I insert the doors the walls dont open up.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
You don't have any doors and windows.
...oops. found two windows.  no doors though.
...plus, your Floor Plan View's Cut Plane is way too high. Lower it.
Nachricht 3 von 3
The same thing happened with me and you should double check that the wall and door/ windows have the same properties when you are choosing NEW or Existing element feature.
you can find that under element properties- phasing-phase created
check the attachment as well.
Best of luck!
