Windows and doors do not cut wall
osnNCX5J
osnNCX5J
Hello
I have taken over a revit project from the previous creator and there seems to be a problem only when i place windows. All previous windows and doors apear as they should, except for the ones i place. All the parameters are the exactly the same and the window is the same type as the others show, i can only see the window sill and the outline of the wall opening:(
mar_zan
Hard to say without experimenting with file. Two things I can think off the top of my head.
1. Are there two walls layered? The walls will need to be joined for the window families opening cut to cut both walls.
2. Check window family opening cut. Is it an opening cut or a void. Perhaps something weird going on here.
Generally, when I get issues like these, I try to narrow down why it's happening by experimenting. Open a new file, load the window family in, apply it to a new wall. See if problem repeats, and start messing with things.
rosie_lucas1
Hello @osnNCX5J,
Did the information provided by @mar_zan help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Rosie| Community Manager
Rosie | Community Manager
osnNCX5J
Weirdly eveything seemed alright, i just had to delete the wall and place the exact same window and wall again and now it works:/
