Windows 11 compatible
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
brianwclayton1969
3036 Aufrufe, 6 Antworten
Good afternoon, I have seen that Windows 11 is out, this is a general question about Autodesk products. I was wondering are AutoCAD and Revit versions compatible with Windows 11 now or do users need to wait couple of months before updating to Win11.
Thanks Brian
6 ANTWORTEN 6
Nachricht 2 von 7
Hi, I haven’t found any problems installing Autodesk products in windows 11. Also, updating windows with my adsk programs already installed neither.
If I helped you, please mark as a solution. Thanks.
Nachricht 3 von 7
Hi, I haven’t found any problems installing Autodesk products in windows 11. Also, updating Windows with my Autodesk programs already installed neither.
If I helped you, please don't forget to mark it as a solution. Thanks.
Nachricht 4 von 7
edwin.prakoso
als Antwort auf: brianwclayton1969
If you check AutoCAD and Revit system requirements, Windows 11 is not listed as a supported OS yet.
I would wait until it is officially supported, especially for the production environment.
Cheers,
Edwin Prakoso
Nachricht 5 von 7
brianwclayton1969
als Antwort auf: edwin.prakoso
Thanks for your assistance.
Brian
Nachricht 6 von 7
This post indicates AutoCAD 2021 and 2022 fully support Windows 11 even though it is not listed on the system requirements page for AutoCAD
Nachricht 7 von 7
RDAOU
@brianwclayton1969
It is compatible and Autodesk did extend support to cover windows 11
https://blogs.autodesk.com/revit/2021/12/01/autodesk-revit-now-supports-microsoft-windows-11/?_ga=2....
