Windows 10 und Revit 2016
10 REPLIES 10
Message 1 of 11
1001 Views, 10 Replies
Hallo Community!
Weiß jemand wann Windows 10 offiziell von Autodesk Revit 2016 unterstützt wird?
Bisher betreiben wir 3 PCs mit WIN10 und BDSP 2016 mit R2, jedoch wurden die System bereits mit WIN7 betrieben und das BDSP 2016 war schon dort.
Jetzt planen wir einen Computerwechsel/Neukauf mit WIN10 und sind besorgt das die neuen Geräte eine Installation nicht zulassen...
Danke.
10 REPLIES 10
Message 2 of 11
L.Maas
THIS is the official Autodesk page with comments about windows 10 support. I do not think you will get more information than this.
However in the mean time lots of people have installed Revit on Windows 10 computers without problems.
You could purchase 1 system and see if it works. You als can check for a new computer with windows downgrade options.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 11
in reply to: L.Maas
Thank you!
But this i allready do know.
i wantend to know when it will be supported officially!
we plan also to make to all computers which were updated from WIN7 to WIN10, a clean WIN10 insatallation,
and reinstall all software, to loose all the old system-mis-matches we collected.
but for this we need a new machine, as backup.
So thank you again.
Message 4 of 11
many threads on Windows 10
other threads on this subject: http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=labels&q=windows+10
you may want to start looking at those
Message 5 of 11
L.Maas
I also would like to know. In same postion as to upgrade all computers in netwrok to windows 10. The page I mentioned is the official Autodesk page. I think nobody can/will tell the community until it gets official released by Autodesk. I assume they are running all kinds of tests and making modifications to their products where needed. As soon as they have completed the tests/modifications and satisfied they will release a statement.
They probably have internally a timeline for this whole process but will not release it in case they run into issues causing delays. That is why I mentioned "I do not think you will get more information than this."
Louis
Message 6 of 11
in reply to: L.Maas
OK,
thank you anywhay!
We keep looking for that day!
Message 7 of 11
Thank you,
we will do!
Message 8 of 11
Also wir haben nun alle Rechner im Büro aktualisert / neu gekauft:
1. Mobilrechner 1x :
mit WIN10 pro und 4K Monitor:
Funktion und Installation BDSP2016 soweit OK,
Bildschirm mit 4K: katastrophe mit Revit: Mini-Symbole kaum lesbar, im Feld nicht wirklich nutzbar
Lösung: Bildschirmauflösung: Umstellen auf 1920 x 1080
na ja
2. Workstation 2x:
aus Mangel an WIN10 Unterstützung zunächst mit WIN7 (!)
bisher keine Probleme
WIN10 Status:
Autodesk spricht nun davon das "viele" 2017 Produkte unterstützt werden.
Wir warten es ab...
Message 9 of 11
Termin zur Veröffentlichung von Revit 2017
(mit der dringenden Hoffnung auf WIN10 Unterstützung):
Wir haben dies bei unserer Recherche gefunden:
14. April 2016 in Japan...
http://news.mynavi.jp/news/2016/03/23/166/
vermutlich wird es die deutsche Version dann irgendwann im Mai 2016 geben,
und dann sehen wir ob und wie Revit 2017 mit WIN10 funktioniert.
Interessant wäre die Frage ob dan die Touch-Bedienung eines Monitors implementiert wird...?
(momentan nein: Test DEL XPS15-9550 mit WIN10)
Tags (1)
Message 10 of 11
OK, es ist offiziell Revit 2017 überstützt Windows 10!
http://help.autodesk.com/view/RVT/2017/DEU/?guid=GUID-2EF1661C-5A8D-41AC-A28F-9678DDF545CA
jetzt sind sind wir gespannt ob auch Multitouch unterstützt wird...
und,
ob es sinnvolle Neuerungen gibt...
Tags (1)
Message 11 of 11
Revit 2017 - und BDSP 2017 in Deutsch seit heute 06.05.2017 verfügbar!
