Windows 10 Home Compatibility with Revit
2 ANTWORTEN 2
Nachricht 1 von 3
578 Aufrufe, 2 Antworten
Is Windows 10 Home instead of Windows 10 Pro / Enterprise fine for Revit?
Considering the fact that other configurations as mentioned at https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/S... are in place.
2 ANTWORTEN 2
Nachricht 2 von 3
ennujozlagam
als Antwort auf: Anonymous
yes it does in windows 10 home. thanks
Nachricht 3 von 3
Win10Home is not a supported OS.  If you go here and search "Windows 10 Home" you are going to get a lot of distressing information -- and some not so distressing.   Bottom line: Install away. What's the worse that can happen? You have to upgrade your OS. Right?
 https://forums.autodesk.com/t5/installation-licensing/bd-p/24
