Window Tags of Linked Models - Sequential
I'm fairly new to Revit, we are working on a townhome project with 19 units total in 2 buildings on 1 site. Each unit is linked into the specific building model, then the building models are linked into an overall site model.
In the Site Model I want to tag all of the windows and then produce a schedule with each window having a unique (non-repeating) number. Currently the window tags are showing repeated numbers.
I know that I can go into each unit model and individually change the Mark for each window to have them populate into the schedule, however this would take a long time and not be helpful down the road when we potentially add windows.
Is there a way to tell Revit to start the Mark number at 1 for the first tag I place (and then sequentially increase) no matter what the window mark is within the unit model? Or is there a way to edit the window family so that within my Site Model the tags will assign unique mark numbers to each window?
Ideally the tag marks would be in order too, so that as you look for Window 06 it would be in between or near Windows 05 and 07.
Again, I'm fairly new to Revit and am not well versed in how to customize/create shared parameters in families.
