Window Tags and Schedule
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
PhilvK
7037 Aufrufe, 9 Antworten
I’ve created a sample project and inserted 5 windows into the walls. The 5 windows are comprised of only 2 types. When I create a schedule however, each window has its own “mark” numbered consecutively. How to you get the tags on the plan to match the schedule? I apologize if this is incredibly simple, I just can’t find it.
9 ANTWORTEN 9
Nachricht 2 von 10
BIMologist_
als Antwort auf: PhilvK
The Window TAG is using the TYPE MARK and the schedule is using Mark (Instance)
Open the Window Tag Family. / Edit Family
then follow the graphics
Load it back in the project.
BIMologist / Dr. Revit
Approved Autodesk Services Marketplace provider - BIM Consulting
If you find this reply helpful, please use the Accept Solution or Like button below
Nachricht 3 von 10
PhilvK
als Antwort auf: BIMologist_
Got it! Thanks.
Nachricht 4 von 10
PhilvK
Is it possible to have both the Tag Mark (number) and the Type Mark? For instance, if I have 30 windows, and only 3 types, I get a schedule with 30 entries, and each entry Type is either "A", "B", or "C".
Nachricht 5 von 10
David_W_Koch
You should be able to create a custom tag that has both the Type Mark and the Mark parameters (in separate labels or in the same label, depending upon how you want them displayed).  Keep in mind that Revit will want all of the Mark parameters to be unique, and will give you a warning if they are not.  So if your Type Marks are letters and your Marks are numerals, you could have A1, A5, A7, B3, B4, B8, C2, C6, C9.  If you want A1, A2, A3, B1, B2, B3, C1, C2, C3, you will get warnings about the identical Mark values.
From your description, it sounds like you are showing the Type Mark in your schedule.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Nachricht 6 von 10
Clear, correct and concise. Txs!!
Nachricht 7 von 10
exactly what I have been looking for. many thanks! cheers!
Nachricht 8 von 10
L.S.
I'm having the same issue with window tags (wanting to have unique tags for each window regardless of type), so I followed your steps to fix the issue, but I must be doing something wrong because it's not working. Any idea what's going on?
Nachricht 9 von 10
yes_and_no
als Antwort auf: L.S.
Create separate labels, Mark and Type Mark, align them next to each other in yr tag family, reload.
Nachricht 10 von 10
luisPDAN6
We usually have a tag that has Mark and Type mark in separate lines of the same label. The mark gives the unique number, usually related to the room for geographical location, and the Type Mark gives the ID of that type for specification and fabrication.
