Window tag not loaded according to alert, but it is loaded
1 ANTWORT 1
Nachricht 1 von 2
pskerry
299 Aufrufe, 1 Antwort
See attached screen shot. I'm trying to tag the window on the lower right. The window tag below the alert was created months ago. When I give-in and try to load one, the file overrides the family and we circle back to where I was. Any possible reasons? I did find a workaround using "Create similar" button.
Thanks!
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: pskerry
If I understand correctly, your tag (the one you "create similar" to) might actually be a multi-category tag; not a window tag.  Edit Family and check its category to confirm.
