Window tag in elevation view does not move when window is moved. See attached video. This is in Revit 22.0.2.392.
What can be causing this?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Start with installing latest patch Revit 2022.1
Latest build is 22.1.1.516
I believe it is related to the Multi-Leader functionality. I remember a similar post about this issue.
...I just tested. It's replicable.
Hey @tcarrollB6KKH- just swinging back by with this link for you:
Solved: Re: Tag temporarily pinned after placement - Autodesk Community - Revit Products
This is the thread I was remembering - or one of them at least. There has been others. Anyways, it sounds like what you are experiencing. Hope it helps.
Have a good one.
Thanks all for the help! The link to the "Tag temporarily pinned after placement" was spot on with the issue.
