Window Sill Height varies
4 ANTWORTEN 4
Nachricht 1 von 5
jrobledo1
342 Aufrufe, 4 Antworten
Hi all, I've got some oddly shaped windows that have varying sill heights (at an angle). because the family sill parameter is native to window families, it shows a reference point at one of the heights. I'd like the schedule to read "varies" under the sill category, and then dimension it in the window elevations. Is there a way to change the sill category to say "varies" or a custom term?
4 ANTWORTEN 4
Nachricht 2 von 5
hmunsell
als Antwort auf: jrobledo1
would this work for you?
Howard Munsell
Nachricht 3 von 5
jrobledo1
als Antwort auf: hmunsell
Is that going to change them for all windows though? I just want specific ones - most have a rectangular shape and I want actual sill height displayed.
Nachricht 4 von 5
That is for displaying multiple values in one row when you Unitemize instances for the schedule. It does not work when your schedule is itemized; or when your schedule is unitemized, but the windows of the same row have the same Sill Height.
A hack to use that function:
- place two exact copies of the same window, with everything identical, but different Sill Heights, hide one
- sort your schedule per Mark, unitemize every instance (so that those identical windows collapse into one row), and set Multiple values indication as "Varies"
Nachricht 5 von 5
What about another format? Instead of "varies", why not black the "Sill Height" out for those variable sill height windows via a conditional format?
Other possible formats:
