window schedule 'room from' parameter using calculation point in a linked file
1 ANTWORT 1
Nachricht 1 von 2
infoK3R2R
213 Aufrufe, 1 Antwort
On a larger project it is common to split the envelope model and the core and shell (base build) model. The rooms are located in the base build model and the windows are in the envelope model. I want to schedule the windows' instance room number using a 'room from' calculation point but referring to the rooms in the linked file. This is possible with third party add ins or dynamo, but wouldn't it be great if Revit could just do this out of the box?
1 ANTWORT 1
Nachricht 2 von 2
ridantuo
als Antwort auf: infoK3R2R
And to the Revit Ideas you shall go if that is the question :strahlendes_Gesicht_mit_lächelnden_Augen:
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
PICNIC: Problem In Chair Not In Computer.
Around 90% of issues can be explained by human error instead of an actual error.
