window schedule orientation/format
5 ANTWORTEN 5
Nachricht 1 von 6
stephanie6B48Z
289 Aufrufe, 5 Antworten
Hi all,
I would like to make a window schedule with the elevation of the window within the schedule.  This I know how to do (I think).
However, I'd like to run the window numbers across the top row instead of down a column.  I haven't found an option of doing this.  (currently the schedule sets up window numbers in the one column, and therefore data for each window is in a row.  Does anyone know if this can be changed?  I've attached a screenshot of what I don't want BTW, the default revit schedule.
I know there is a workaround of doing a separate elevation for each window and then text below, but I'd like to keep it in a schedule for efficiency if this can be done.
Thanks!
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: stephanie6B48Z
No can do.
Nachricht 3 von 6
ralphdenhaan
I don't know if I understand you correctly, but are you trying to get the elevation as in the "orientation" of the window? Like the example below?
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Nachricht 4 von 6
stephanie6B48Z
als Antwort auf: ralphdenhaan
Hi Ralph,
No, but that's cool!
I'm trying to change the x and y axis in the table - if you can call them that....  (Have the header row running as the first column)
Nachricht 5 von 6
stephanie6B48Z
als Antwort auf: barthbradley
Thought that was the case.  Thanks
Nachricht 6 von 6
ralphdenhaan
Ah:), well that's not possible as @barthbradley already mentioned (at least not in Revit).
