Window Schedule - Material
5 ANTWORTEN 5
Nachricht 1 von 6
767 Aufrufe, 5 Antworten
Hi all. I have created a legend to show the window elevations.
In the legend the window appears with the colour of the material, black colour, and lines cannot be read.
My question is, how can I show the elevations without the material colour?
I have tried to set the view with hidden lines, also I applied a view template with windows/projection is a solid white colour but It didn't solve the problem.
Help appreciated.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Hidden Visual Style.
...can't you get what you want through Graphic Overrides?
Nachricht 3 von 6
als Antwort auf: barthbradley
@barthbradley
When applying hidden visual style makes no difference, still colour is shown on the elevation...
Nachricht 4 von 6
that applies only to the projection lines not the surface if you know what I mean
Nachricht 5 von 6
Something doesn't compute here. Do you have existing Graphic Overrides applied to the Windows?
Actually, can you post the file?
Nachricht 6 von 6
VG > turn off surface pattern.
