Hello i have created some windows/window schedule which was working really well, i bought all the windows into a colleagues project. I then copy and pasted in the schedule but not all the cells are filled in? somehow my parameters have got lost, does anyone know the best way to sort?
Gelöst! Gehe zur Lösung
Gelöst von bimscape. Gehe zur Lösung
I'm assuming you created a range of additional Shared Parameters for your Window Families?
Does you colleague have access too your Shared Parameters File- so his project can link up the parameters used in your windows and utilise them in the Schedule?
Yes exactly i created shared parameters, so these don't get bought in automatically when you bring in the windows+schedules? do i need to point the project to these parameters some how?
Yes, in Revit go to the "Manage" menu and select "Shared Parameters"- then point it at the file's location.
You Project can now interrogate the Shared Parameters File and cross-referenced the parameters it is finding in the Families- and then use these in Schedules and Tags. Without this point of reference, the parameters are "quarantined" within the families themselves.
