I have 2 door types from the same family, each one with different sill heights. The view range is at 145cm enabling the cut of both, but window 2 has a different representation.
I have also checked the view range in the family, and it seems to be ok.
Does anyone know what can be causing this?
Window & door families are not cut based on the cut plane defined in project views. Instead they are cut based on the cut plane defined in the family's plan view.
I am not having the same issue as yours. Do you have plan region within those area? Is the window frame set as nested shared family?
