Window opening insert into walls and material wraping
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
studioconverge
1921 Aufrufe, 7 Antworten
I created a flared opening with a window family. It works pretty well except that in medium detail you can see that the wall materials do not wrap up to the window. It looks like the materials wrap up to the wall centerline. How can I control this so that I can make the interface look correct? See attached JPG image file where I mark up the area in red.  I guess I could make a generic solid wall and just show that interface in a drafting detail. Any suggestions are greatly appreciated. Thanks.
Beschriftungen (2)
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: studioconverge
Set the reference plane that define the exterior face of the window in the family as Wall Closure.
Nachricht 3 von 8
martijn_pater
als Antwort auf: ToanDN
What Toan said and also set the wrapping condition in the window type or the wall type at inserts...
Nachricht 4 von 8
studioconverge
Thanks.
Another question I have is how the materials can wrap in the head and sill when you cut the wall in section? Does that need to be done by editing the wall layers?
Nachricht 5 von 8
studioconverge
als Antwort auf: martijn_pater
Thanks!
Nachricht 6 von 8
Wall wraps are cosmetic and on plan only, you cannot wrap the layer at head/sill in section. To show them graphically in section you need to go to View > Cut Profile and edit the cut profile of the wall layers.
Nachricht 7 von 8
studioconverge
Thanks!
I cut the profile, but the jamb beyond stays straight (See image circled in red). Also, how does the cut profile still remain as a thick line like before editing the profile (see highlighted image with red arrow)?
Thanks.
Nachricht 8 von 8
I would replace the Cut Opening with a Void in the family to create the sloped sill geometrically correct. That would take care of most of the issue you show above sans the wrap, which would be done using Cut profile.
