Hello, can someone help me with this problem? When I place a window it creates an opening cut that is bigger than the window itself. I would like my opening to be as big as the window and I don't know how to fix that. It looks weird. I attached a photo so you can see what I mean because I'm not sure if I explained it correctly. Thanks in advance!
oops yeah I edited it and added the photo, I also attached the window below
After taking just a quick look, your right side jamb (viewing from the interior) doesn't appear to be locked to the opening's reference plane.
and could you please tell me how can I lock it to check if it's going to work this way?
You have got a couple of issues to resolve. First of all, your Nested Family's Parameters, that control its sizing, need to be Instance types, and second, those Parameters need to be Associated to Parameters in the Host Parent Family that is is Nested into. Do you follow? I can revise your family and return it to you, but it will be in 2020. Can you open 2020?
...also, you need to check 'Work Plane-Based" in your Nested Family and Host it to a Ref. Line Work Plane or Named Ref. Plane Work Plane in the Parent.
yes, I can open 2020! I would love for you to revise my family if it won't be a bother for you! I couldn't really follow, I'm kind of new to Revit and I don't understand it that good yet
