Window opening cut material?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
VaclavC
2304 Aufrufe, 4 Antworten
  sorry for probably dumb question, but I' am unable to figure it out. How can I change material of window opening cuts in walls? In attached image, I have a (ugly) red material on wall exterior. I want the same material on wall cuts around windows. There is some default material right now.
Sure, I can paint it (PT) manually, but this is very inconvenient for large number of windows.
4 ANTWORTEN 4
Nachricht 2 von 5
cbcarch
als Antwort auf: VaclavC
You can do this by:
In the Wall Properties, Set Wrapping at Inserts to Exterior, or Both
You can also improve the return of materials into the jamb by editing the window family--
see this:
http://www.revitzone.com/3d-modelling/184-wall-wraps-and-wall-closures
https://forums.autodesk.com/t5/revit-architecture-forum/endcaps-in-revit/td-p/1525791
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 5
VaclavC
als Antwort auf: cbcarch
Ah, Wrapping at Inserts was what I was looking for. Thank you!
Nachricht 4 von 5
what could be the other solution aside from wrapping at inserts? I want to keep my wall "without wrapping" and at the same time, have the same default material as my wall core? (i don't know how it happened but my wall edge has a default material which is wood. I want to keep it just block material) Thanks
Nachricht 5 von 5
bin
als Antwort auf: Anonymous
Check the Object Style under Wall Category.
