Window not cutting wall in elevation
3 ANTWORTEN 3
Nachricht 1 von 4
Mbateman10
279 Aufrufe, 3 Antworten
I've placed a window in plan view, and it shows up properly. When I try to view this same window in an elevation it doesn't properly cut thru the existing wall and doesn't show up. If i hover my mouse over the correct spot it will appear as if it is in the wall.
 - The window appears properly in new walls but not existing. The window does appear properly in existing walls when placed as an existing window.
3 ANTWORTEN 3
Nachricht 2 von 4
kostask_oionei
als Antwort auf: Mbateman10
Change the Elevation Phase Filter to "Show Complete".
Otherwise there is a part of wall as demolished.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
Nachricht 3 von 4
anze.kumar
You can also change how you want Window to be seen in different Phase Filters under Manage -> Phases
Nachricht 4 von 4
handjonathan
Hi @Mbateman10
Thanks a lot for posting your question to the forums!   Has the solution suggested by @anze.kumar & @kostask_oionei  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
