Window not cut correctly in floor plan
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
AthenMar
322 Aufrufe, 4 Antworten
I have a problem with a window not showing according to the cut plane (as set in the family editor). I started from an existing autodesk window family and made some changes to it but now the mullion in the middle does not appear cut (see picture). The view range and visibility settings are the same in both, and both appear correctly in the preview mode of the family editor. I cannot figure out what the problem is :weinendes_Gesicht:
I have attached both families, thank you in advance for your help :leicht_lächelndes_Gesicht:
4 ANTWORTEN 4
Nachricht 2 von 5
Simon_Weel
als Antwort auf: AthenMar
I had a look at the families and they have this big extrusion covering the whole thing, with 'glass' as material. Don't know why it's there, but it seems to interfere with the other elements?
Nachricht 3 von 5
AthenMar
als Antwort auf: Simon_Weel
Thank you for taking the time to view the families. This extrusion is just for the coarse detail level. All my windows have it and it doesn't cause any problems. Anyway I tried deleting it just in case but the problem is still there... Eventually i gave up and used a detail component :).
Nachricht 4 von 5
TripleM-Dev.net
Just for future reference, delete the "Ref.-Ebene Kopie 1" floorplan in the family, then it will display correctly.
- Michel
Nachricht 5 von 5
AthenMar
als Antwort auf: TripleM-Dev.net
Thank you so much!!!
