Hi everyone,
i'm having some problems with a window that i take from the revit library. I don't understand why it doesn't showing materials/colours that i have assigned to every component of the window in the plan view. I can see them in section in elevation or in 3d view but not in the plan view.
The only thing that i noticed is that the window has every component nested. Can someone help me to understand why?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
The Window Geometry isn't Visible in Plan/RCP View. What you are seeing in Plan View is Symbolic Linework and Masking Region.
...actually, the Plan View is showing a Detail Item Family. Again, the geometry is not visible in Plan/RCP.
ok, is it possible to change this to make the geometry visible in plan view? how can i do this?
Sure, change the Visibility Settings of the Geometry (e.g. check Plan/RCP) and get rid of the Detail Item Family.
See screenshots I added to my first post.
depending on the family your using, it may be a Nested Family used to display only linework and mask out the model content. you can edit the family as @barthbradley shows above and remove the nested family, but you will likely loose your swings.
the image on the left is the family where i moved the nested family. the image on the right is the same window in a wall. you will possibly need to select each element in the family and change the Visibility settings to display in Plan view as well.
Howard Munsell
i followed your instructions but now i have another problem
. Now when i load the family inside a project it doesn't shows the lines that compose the windows frame. i re-attach the family if someone want to check.
