Hi!
I made a very basic custom window for my sloped wall. It looks totally fine in 3D, but doesn't cut in plan (see images attached)
Any possible way to get it to cut according to the cut plane?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Model the jamb/sill and header as 2 separate elements. Set them to Display when Cut in plan/rcp.
Looks like your Plan View's View Range Cut Plane is cutting below the Window - not through it.
...ever hear about the old invisible line trick? It's an alternative to changing the View Range Cut Plane or applying a Plan Region.
https://revitoped.blogspot.com/2008/01/aaaahthe-old-invisible-line-trick-eh-99.html
