Hello everyone
How can I make the glass material in a window and in it's nested family transparent in elevation?
The cut in the wall is made with void instead of the default opening cut.
Check this
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
You can apply a different subcategory to the glass and hide it in the model, or model the glass in an independent family with a different cattegory and modify this cattegory visibility in the model
