Window Frame Depth
3 ANTWORTEN 3
Nachricht 1 von 4
dm0144
273 Aufrufe, 3 Antworten
Window Frame Depth
Hello everyone
How do I create a frame depth, which is always equal to the depth of the structural layer of the wall and, at the same time, the frame is attached to the edge of the structural layer(not in the middle per say)?
3 ANTWORTEN 3
Nachricht 2 von 4
RDAOU
als Antwort auf: dm0144
@dm0144
Instead of modeling the frame locked to the inner and outer layers of the wall, Lock to Interior face and the other end lock to a reference plain with a wall depth parameter...use than to adjust the frame depth in the project
Option 2: Leave door as it is and model your wall using 2 Wall elements ... then join them. The door will cut both walls but frame depth will be equal to the thickness of the the host wall
Nachricht 3 von 4
dm0144
als Antwort auf: RDAOU
@RDAOU
in the first option, is it possible the parameter for the frame depth to be linked to the layer depth of the wall, maybe with some global parameter?
Nachricht 4 von 4
RDAOU
@dm0144
Can but not directly...
  1. You can use a global parameter in the project for each thickness/wall structure type and associate that parameter with it (The global parameter will need to be entered by you, it will not read directly from the wall)
  2. You can use dynamo...
    • First step would be to get all elements of the Doors category
    • Get their Host
    • Then there is the package Genius Loci I believe which has a node that gets properties of structured/layered elements...you can use it to get the thickness of the layer you need and set it to the parameter of the doors hosted in each wall
