Window Frame - Can't Sweep Profile
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
509 Aufrufe, 5 Antworten
I have created a profile for my window family but I seem to be unable to create a sweep from it. I am simply told that the profile contains no loops. Am I not allowed to have two loops in the same profile perhaps? I did try deleting one but I had the same issue.
I've tried trimming all corners, checking for overlapping lines etc...
File attached.
Many thanks
Beschriftungen (1)
5 ANTWORTEN 5
Nachricht 2 von 6
ennujozlagam
als Antwort auf: Anonymous
try this profile attached and see if helps .thanks
Nachricht 3 von 6
als Antwort auf: ennujozlagam
Thanks, that works now. What did you do to make it work?
Cheers
Nachricht 4 von 6
ennujozlagam
oopss sorry take this profile forgot to remove the guide ignore the first one. thanks
Nachricht 5 von 6
ennujozlagam
just recreated a new one. it could be some issues in your profile. thanks
Nachricht 6 von 6
Martijn.Pater
Probably you had some lines not meeting properly at a corner, trimming those to meet would resolve the issue (check the loop sketch)...
