Window Family View Range
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
1228 Aufrufe, 6 Antworten
Hello Everyone,
I just created two window families that don't appear correctly in the project floor plan (they do appear correctly in the family reference level though).
I assume the problem comes from the fact that the opening is nested in the main window family, and it (only the opening) doesn't get cut properly. I tryed already to change the view range both in the opening family and the window family and couldn't find a solution.
Does anyone have an idea how to solve this Problem? I would like to avoid drawing lines and would like the window to get cut properly. Familys attached here (Revit 2019)- the one on the right works properly, i dont know why. Cheers!
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
Is it not just the view range?  I moved it up and the glazing became visible.
Nachricht 3 von 7
David_Knight
Never mind, i misread something.
Nachricht 4 von 7
:nicht_sprechender_Affe:
Nachricht 5 von 7
als Antwort auf: David_Knight
Nachricht 6 von 7
als Antwort auf: barthbradley
yes it was just the view range in the main file - i spent so much time trying to change the view range in the families… silly mistake
Nachricht 7 von 7
David_Knight
i was going to suggest the view range.  had it typed out and posted, re-read the info... where it was said it was attempted. lol.  so i just attempted to delete my post - but apparently you cant.  so i just edited it back to whats up there now.
