Window family shows opening in family view but now project please help
10 ANTWORTEN 10
Nachricht 1 von 11
timpanofmt
988 Aufrufe, 10 Antworten
I have looked at a bunch of old forums on issues similar and have tried to change the cut plan and change the visibility settings however none work. when in the family ref view it shows the walls cut however when in place it in a family it will not. can someone please help me fix this? i have attached two screen shots off what is happening
Beschriftungen (3)
10 ANTWORTEN 10
Nachricht 2 von 11
L.Maas
als Antwort auf: timpanofmt
Best to upload the family (or better project) so we can have a look what you have.
Might be a something as simple as the the view range
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 11
Window & door families are not cut based on the cut plane defined in project views. Instead they are cut based on the cut plane defined in the family's plan view.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Nachricht 4 von 11
timpanofmt
als Antwort auf: L.Maas
Heres the family file
Nachricht 5 von 11
Change the Category to something other than Windows or Doors (e.g. Generic).
Nachricht 6 von 11
timpanofmt
als Antwort auf: barthbradley
  • how do i change the category
Nachricht 7 von 11
Lachlan-JWP
By default the window opening is 1219mm above the hosted level. If the cut plane for your floor plan is at the default (1200mm) then the family won't display correctly. Make the cut plane higher or use a plan region around those windows.
Nachricht 8 von 11
If you really must, you can recategorize just about any Revit Family this way:
...but, I am not advocating you do this in your case.  Did you read the AKN Article I linked you to above?  Did it make sense to you?
Nachricht 9 von 11
FWIW: this family needs a lot of TLC. Much of the geometry in it is unconstrained or improperly constrained, and some of the parameters do nothing, while others cause it to break to smithereens.
Just thought you should know.
Nachricht 10 von 11
timpanofmt
Thank you! I am new to making my own family and trying to learn so any advise on how you would have made this would be appreciated
Nachricht 11 von 11
timpanofmt
I did not see a link I will have to look again in the morning. Thank you
