Feel like I'm missing something... but struggling with the window families in a Revit project that are only every graphically showing a solid color fill when cut in plan. I've verified that the problem is definitely the window family, and not any Revit Project settings, element settings, or view settings within the project as windows copied from other projects display correctly and the suite of window families causing problems are graphically showing the same issue when pasted into other projects (new and old).
It feels like the issue is somehow material related? Only considering because the graphic fill color it always shows seems to coincide with the Mullion material color. But I'm unsure why that material would be covering the cut glass pane and other poche cut fills. I've attached one of the window families from the suite, alongside some screenshots. Help would be greatly appreciated! Also, this is my first time posting to the forum so let me know if the post is in the right place or there's somewhere else I should have looked first, thanks!
the bast way is using the frames not complate one,upper frame,below frame and etc. then make the upper frame not visible in plan view:
something like this :
