Hi everyone, I really confused, I created a window family, but it shows the glass even though I created masking. I have attached the window family as well. So appreciate any help.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Hi @Anonymous! I am even more confused than you are! When I insert the family into a vanilla project (file attached), this is what I see -
Looks pretty darn perfect to me!! Great job on the family too!!
My first guess is symbolic lines.
...sorry, not at a 2018 workstation right now to be able to view your file.
I think I see what you are talking about now. Your masks are drawn with Window Projection lines. You are seeing those lines in plan view, not the model below.
BTW @Anonymous, Nice job on the "Precasts".
Select the glass extrusion and turn off its Plan visibility. Same can be applied to the window units if you only want the masking regions to show on plan views.
