Window family not showing in Legend properly.
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
iustinXVWHB
280 Aufrufe, 3 Antworten
I have a nested family. I am trying to create a legend component elevation. It is not showing the family which is nested in the window family. Can you assist.
Beschriftungen (3)
3 ANTWORTEN 3
Nachricht 2 von 4
syman2000
als Antwort auf: iustinXVWHB
Your nested families are shared and will not be part of the whole window legend. You have to add all those 3 items into the legend to create your complete window.
If you don't want to do that, your best bet is to create a window elevation/section and have your window hosted in that elevation.
Nachricht 3 von 4
iustinXVWHB
als Antwort auf: syman2000
Thank you, I will have to use the sections to create the legend.
Nachricht 4 von 4
You can TAB select the nested components and create an Assembly, then use an Assembly elevation view for Legend.
