Window family detail subcatagory lines-glass showing as blue in Plan view.
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
julie6V67T
1194 Aufrufe, 3 Antworten
I have a window family that in Plan View- interior lines show as blue in project. I changed all lines and object styles to black in family and in project, window still reading as blue. Please help.
Tags (1)
Beschriftungen (1)
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: julie6V67T
Change Window glass subcategory under Detail Items in project.
Nachricht 3 von 4
julie6V67T
Where can you go to manipulate Detail Items? Is there a way to change this in the family so that I never have to change these in any project moving forward?
Nachricht 4 von 4
It is because an detail item family is nested in your Window family to represent the glass.  You can edit the nested Detail Item family and change Window Glass subcategory from blue to black, then reload it to the Window family.  Load it in any new projects and it will show as black.
However, for your current project since you already loaded the family in, you must change the Detail Items subcategory in the Project's Object Styles:  Manage menu > Object Styles > Model Objects tab > Detail Items > Expand to see the subcategories and change the color of Window Glass.
