Hi guys,
I want to achieve "this" attached below above my windows, how would I do that. Thanks!
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
See “Joint Radial Array 3 of 3.rfa” and “Brick Radial Array 3 of 3.rfa” in the attached RVT.
Thanks man,
I wanted to see if I achieve this in 3D also, so without the lines but this does the job so it's okay. I guess I can use this for straight lintels as well just eliminate the angle and use a normal array.
