I'm attempting to change the window dimensions for a specific window. I change the dimension of that specific window and Revit changes the dimension for all the windows I put down. How can I stop this from happening?
@Anonymous
The dimensions you are changing are type parameters...
Question
What is the difference between instance and type parameter in Revit?
Answer
Instance Parameter – Enables you to modify the parameter value separately for every instance.
Type Parameter – Enables you to modify the parameter value, which applies to all elements of the family type.
Difference between Instance and Type Parameter - Revit – Cadline Community
https://www.youtube.com/watch?v=U6Hc26vqTO4
