I have a Window that is not displaying the frame and Mullions in Plan View. It is being placed in the wall, but it only shows the outline of the Window. I thought it was a View Range issue, however, I have adjusted the View Range with no results. I have also checked the View Range in the Family, and it has a cut plane at 4'-0", and the default sill height is at 3'-0". It should be cutting, but is not. It is set to display in all views, so I am stumped. Does anyone have any idea why it is not displaying? Thanks for your help.
you can try this see screencast or share you family so we can check and see if helps. thanks
Are you working with Phases? They can be interesting to learn/understand.
Can you send me your window family ?
maybe i can repair it,
i think le problème is the frame.
