Hi!
Does somebody know what drives the snapping points in this window family? When I want to annotate the drawing, the snapping points are annoyingly in the way of the drawing. Also when I automatically tag the window, it's placed way out of the drawing. Reference planes in the family seems first thought, but they look ok and not overextended. I also tried to play with crop region in the family, but no resolve. Any other thoughts?
Thanks in advance!
Gelöst! Gehe zur Lösung
Gelöst von rxi.gg. Gehe zur Lösung
Can you upload the window and the annotation to check them please?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
The problem is this family inside the window family
If you enter inside to edit it you can see very long reference lines
I try deleting this family in the window of the left and the problem is solved. You must edit that family and thats all!
