winder stairs width
4 ANTWORTEN 4
Nachricht 1 von 5
mtanyer
295 Aufrufe, 4 Antworten
winder stairs width
Dear all,
Is it possible to arrange the gap between the legs of the winder stairs? Also how is it possible to arrange to total width of the stairs (2runs + gap)?
I place a dimension however, it is not a temporary dimension and so I cannot edit it.
Any suggestions?
4 ANTWORTEN 4
Nachricht 2 von 5
EATREVITPOOPCAD
als Antwort auf: mtanyer
It is possible, you have to go into stair edit mode, select stair and you will see handles you can drag. I typically draft detail lines with exact dimensions first and then snap the handles to them. Select the stair and drag those handles around see how each one affects it
The definition of insanity is doing the same thing over and over again and expecting different results
Nachricht 3 von 5
You can increase the space between the two flight by dragging one.  Is that what you mean?
Nachricht 4 von 5
mtanyer
als Antwort auf: EATREVITPOOPCAD
Thank you for the replies.
I can drag the handles. But the results are not precise.
I am looking for a solution that includes entering dimensions (for the whole width of the stairs and the gap between the legs) so that I have a precise end results.
Nachricht 5 von 5
EATREVITPOOPCAD
I think you to do a stair by sketch
