Will not color fill rooms on second floor, says rooms are unbounded
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
713 Aufrufe, 9 Antworten
So it will show that the rooms are bounded, but won't do the color fill because it also says that they aren't.
I am not entirely sure what I am missing. The first floor worked out just fine.
Thanks in advance, I greatly appreciate any help :leicht_lächelndes_Gesicht:
First Floor:
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: Anonymous
Do you have a thin finish floor above the Level? Select it and uncheck Room Bounding.
Nachricht 3 von 10
Hmmm I had Lightweight Concrete on a Metal Deck.
I just changed it to 12" Generic Fill.
I unchecked the room bounding for 1 room and tried to retag it, ran into the same problem :verwirrtes_Gesicht:
Nachricht 4 von 10
Share your model.
Nachricht 5 von 10
als Antwort auf: ToanDN
Btw thank you for all the suggestions, I truly appreciate the help.
Nachricht 6 von 10
I think your Warnings tell the whole story.
Nachricht 7 von 10
You use a roof in lieu of the floor and it is sticking above the level, interfering with room creation.  Set that roof to non room bounding will fix the room issue but if you want to model it as a finish layer then it is way too thick.  Better fix it.  Cut a section and you will see.
Nachricht 8 von 10
als Antwort auf: barthbradley
Bahaahaha
Nachricht 9 von 10
You sir are a gentleman and a scholar.
Thank you so much!!
Nachricht 10 von 10
@Anonymous wrote:
Bahaahaha
What does "Bahaahaha" mean? Google Translate can't even figure it out. Is it Epilepsy?  Haven't been there myself, but I hear it's a pretty nice place to visit.
