Hello! I am just wondering if Model Group Elements in Revit become Blocks if exported in Autocad or will they just be lines? thank you!
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
Gelöst von magnus.enstromBIM. Gehe zur Lösung
No, the whole group will not be automatically created as a Block in the dwg-file. When you have linked files in Revit and export, then you can have a "group of elements" become a block inside of AutoCAD.
what consist of your Model Group Elements ? it become blocks. if you will go to autocad 3d view you will see them with height if export in 3d view . thanks
it only consists model lines, I've tried to export it and it was indeed in a block. but thank you.
oh pardon me.. the "grouped model" i was saying was actually imported cad blocks and exporting them to cad again from revit did make them a block.
once you import or link cad into revit it will become one entity (group) and once you exported to autocad still the same one entity. but once you link/import cad file into revit and use full explode and exported to autocad then your file is also exploded. thanks
Hi, can you explain with more detail how can I export a Revit model file to a CAD file and keeping all the "families" as blocks. We have our Electrical model uploaded in BIM and the Architectural linked to it. Any thoughts? I will appreciate any help. Thank you!
Hi there,
this is not a solution if it's not possible to export grouped elements in blocks in dwg-files.
it's all autodesk!
