Why will section cuts not display in certain plans?
I have adjusted the "display coarser" settings
I have checked the crop area and made sure it is big enough
I have checked that the category is not turned off.
I have adjusted for discipline
What could possibly be the reason my section cuts don't show on some plans?
You can also check the crop region of the section. If the crop region/extents of the section does not intersect with the view range of the level in question, it will not show on that level.
