Why Top mullion profiles lower line cuts another mullion in project, Hower that line and there refrence line is also not a refrence line.
10 ANTWORTEN 10
Nachricht 1 von 11
Biswajit5N4D8
546 Aufrufe, 10 Antworten
10 ANTWORTEN 10
Nachricht 2 von 11
hmunsell
als Antwort auf: Biswajit5N4D8
"Why Top mullion profiles lower line cuts another mullion in project?"
What is the profile shape?
it looks like it has a back leg on it? If so, the bottom of that leg is the bottom of the horizontal mullion. The Vertical mullion will go to the bottom of the horizontal mullion.
Howard Munsell
Nachricht 3 von 11
Mike.FORM
Profiles for mullions work in a way that is not very intuitive. The boundary of the mullion is not the face of the mullion geometry, it is an invisible rectangle that fully encloses all parts of the profile.
Nachricht 4 von 11
The vertical mullions always meet the extent of the horizontal mullion.  It does not matter the you set the line as reference or not.  If you want the vertical mullions to meet to main line of the horizontal mullion then do not add the flange to the profile and model it in place.
Nachricht 5 von 11
PLAN B: Nix the Mullions in the Curtain Wall Type and Model the Mullion and Glazing  Geometry together inside Curtain Panel Family.  Use this all-in-one Panel in the Curtain Wall Type.
Nachricht 6 von 11
Biswajit5N4D8
als Antwort auf: hmunsell
I want this mullion upto green highlighted bottom of mullion, however it stops at lower of its leg.
Nachricht 7 von 11
You're fighting an unwinnable battle.
Nachricht 8 von 11
Biswajit5N4D8
als Antwort auf: barthbradley
:sich_vor_Lachen_auf_dem_Boden_winden:Thank you.
Nachricht 9 von 11
Biswajit5N4D8
If you say so i'll make mullion profile into Panel, Then it will brake at every Vertical mullion.
Nachricht 10 von 11
Leave the flange out of the mullion profile and model it as a beam, railing, or in place sweep.
Nachricht 11 von 11
Biswajit5N4D8
Thank you:lächelndes_Gesicht_mit_lächelnden_Augen:
