Why those lines are hidden?
3 ANTWORTEN 3
Nachricht 1 von 4
354 Aufrufe, 3 Antworten
Goodmorning, I would ask if someone can help me with that kind of problem in a callout view (1: 50 - high detailed).
Why those lines of this windows are hidden? there's nothing which hide it in the model... in the second screenshot can see lines but not visible in the drawing
Thank you very much
3 ANTWORTEN 3
Nachricht 2 von 4
MostafaElashmawy
als Antwort auf: Anonymous
It seems that the view is not cutting at these lines, so they are hidden by the window it self.
Mostafa Elashmawy
Nachricht 3 von 4
hmunsell
It appears you have your view set to Hidden Line(vs Wireframe), those lines are being hidden behind other things. in the second view it looks like you are selecting the window, or at least have your cursor over it. when you do that revit shows you all the "hidden" lifework of the family. when you move your mouse off of it, they get re-hidden.
do you want them Visible?
Howard Munsell
Nachricht 4 von 4
...could be a Masking Region in the Family as well.  Pretty common that Geometry is turned off(and/or hidden by a Masking Region) in Plan/RCP and replaced with Detail Linework is those Views.
