Why Spot elevation value and level value different ?
bimitaly
bimitaly
In the entire project everywhere spot elevation value and level value shows different. as per my knowledge level values are correct. however i don't understand why spot elevation shows negative value.
for your reference please have a look on attached snip.
@ToanDN @fabiosato @Alfredo_Medina @constantin.stroescu
What is the Elevation Base setting of the Spot Elevation? Select one and look under its Type Properties.
Level Elevations are also relative to their Elevation Base.
bimitaly
Thank you, with survey point. i get correct values
