Why should we use 'Connection' to help walls, beams and columns avoid overlaps.
I find that in Revit, walls will not avoid columns and beam automatically. So I have to connect them manually. And related dynamo scripts cannot automate this easily because many of these scripts need us to choose model elements. Both methods are frustrating.
And I used Archicad. Walls automatically avoid beams and columns once they are created.
Why does Revit add an automatic connection for every wall, beam and column?
Yes, it is the 'Joining'. But I mean why doesn't Revit automatically join these elements to avoid overlapping.
It wastes a lot of time to join elements in a large project. And a project without elements joining brings some calculating mistakes in budget calculation indeed. It's annoying.
Use a column that automatically joins to wall.
Thank you. Yeah, I forget this option. Unfortunately, this option is far less robust than the same function of Archicad. It often fails. And I have to draw a void form to activate this function.
RobDraw
Comparing Revit to other platforms is only going to lead to frustration.
Rob
