Why my COBie.Type schedule is blank within revit file ?
I have manage to upgrade revit 2018.3.1 and BIM Interoperability Tool-2018. I am using command called 'Setup Project' within BIM Interoperability Tools which should generate a schedule within COBie.Type ? I have done all the setups but something is stopping me generating this schedule, Could you hep me out please.
JasonKunkel
In the COBie Extension, Setup Project only prepares your model for the COBie data - so it adds parameters, schedules, extensible storage, etc.
Once you setup your project, you need to run the other tools in the proper sequences and at the proper times for your project.
Contacts - create contacts for COBie
Zones - create COBie zones for your rooms/spaces
Select - idenitfy what objects need to track COBie data
Update - populate COBie data in identified objects
Create spreadsheet - generate the exported COBie file.
I would highly recommend watching all the videos here:
https://www.youtube.com/playlist?list=PL0RZIBv0pCfsnVaZwY6ENDYqPeftp320I
This explains all the steps to take for the COBie Extension.
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
CADD Microsystems Blog
RVIT Blog | Twitter | LinkedIn
Thanks, Video is very useful to understand how the COBie extension works.
